Can someone spec me some things to use to clean my car.
I want to wash it/wax remove some light scratches what's good to use?
What colour car do you have? May help.
Normally though
Wash - poorboys stuff is meant to be ace
clay - megs is good
polish - Autoglym Super Resin Polish
Wax - After reading a lengthy review on many many waxes I have opted with Poorboys, but yet to try it.
Invest in some foam applicators and some MF cloths.
The scratches may require something a bit stronger than AG SRP though.
Can anyone recommend a list of products to buy to clean my Clio 200?
I'm not interested in spending 6 hours polishing every inch of the car 5 times but I'd like a decent finish. I simply don't have the time to do that.
Is there a shampoo and then treatment afterwards once the car is dry which will give me half decent results?
Ordered myself some black hole and some Nattys blue, will post up a pic when I get round to using it
They are good for removing spots but I find choosing a good shampoo like the one I mentioned and cleaning the car either early or late in the day out of peak sun probably does more to prevent it in the first place.
Megs UQD gets a great shine and is easy to use but something like Chemical Guys Detail Spray which is synthetic is great as you can use it on all surfaces including the glass even if it does look a bit greasy when you first spray it on.
Thanks for the recommendations. Any suggestions as to where to buy this stuff?![]()
