hopefully ii will not get this issue my should arrive later this weak , how do you fix such issue you have to flash it to new bios the ssd or something![]()
Okay here it is again AS SSD uses none compressible data.
Sandforce controllers rely on being able to do on the fly compression on the data you are writing/reading from the drive.
Thus As SSD is showing the sandforce drives in their worst possible scenario. In those cases if your data cannot be compressed then yes your drive will be that bad. However in 99.9% of the cases your drive will be able to compress the data and you will get the ATTO scores.
To be honest, if it doesn't have one just leave it at the bottom of the drive rack. No moving parts means it won't beat itself stupid while working.Can anyone who already has one confirm if it comes with the 2.5" to 3.5" bracket? The Vertex are advertised having the bracket but can't find anything on the Agility 3.
Mine arrives tomorrow and I don't want to be stuck over the weekend without the bracket.
