New ssd install help
6 Dec 2009
Essex . UK
I have just recived my new vertex 2e bigfoot 120gb ssd and need advice on setting up the drive ,formating , partitioning etc
Running windows 7 64bit
Its my first ssd and dont want to **** it up . lol
setyour bios to AHCI
then there is nothing for you to do
just install it, install windows and it will do it all for you
Just like a normal hard drive ?
How about making a partition ,is it advised as i have read that it can cause a big performance drop ?
for that size i wouldnt make a partition
leave it as one big drive
do you have another drive for your data?
At the moment i have 2 x 1tb f3 in raid . I wanted to put os and programs on diffrent partitions .
When installing the ssd i will obviously have a data drive
imo yes, i dont see any benefit to having a seperate partition for your apps
the SSD is perfect for having the OS/and APPS for snappyness
and then store all your data/music/video/docs/pics/pron etc on your other drives
Right windows installed in 15mins . System is rebooting in under 25 seconds . Just about to start the tedious task of installing drivers,apps,windows updates etc etc
But so far so good;)
