Started changing over the water blocks on the motherboard
Quick pick of how it has been on 'The Shelf' for some time with the Swiftech XT fitted
All the 'extras' stripped off the board
New EK water block fitted to the CPU
A quick rear view
Also decided to do the RAM
RAM stripped down
RAM returned to motherboard to get the correct spacing
After applying same TIM, the block was fitted
Compression fittings put into place
Tubing run into place
Graphics cards fitted back onto motherboard
'The Shelf' has never looked so 'shiny'
A quick rear view
RAM stripped down
