- 14 Sep 2010
- Port Talbot - Wales
At least copper bends easier than ****ing perspex!!
Looking good man, I like those vents!!
 , thanks EniGmA1981
, thanks EniGmA1981  .
. but also it makes taking the window out or the bottom panel out incredibly easy with only needing to untighten the tabs a tiny bit to flip them up or down which releases the panels, also no excess forces.
Yeah I agree with you mate, I think it looks better with the tabs... As you say though, it was worth a try
Just a shame your time was taken up with this and not with any 'genuine' progress
	 what do you guys think.
. so cut it in a wrong spot accidentally, also need to do the diy mesh on the copper panel but got a few shots while there was a touch of blue sky & it really was just a touch
 so cut it in a wrong spot accidentally, also need to do the diy mesh on the copper panel but got a few shots while there was a touch of blue sky & it really was just a touch  .
	That truely is a work of art mate!
 Thank you EniGmA1981
 Thank you EniGmA1981  .
	 lol shouldn't take you long now you've done it once
 lol shouldn't take you long now you've done it once  hehehe
 heheheIt is an amazing piece of work, a true labour of love by the look of it.
However personally I am not too keen on the copper tabs. Functionally I understand them, but I think they are a bit too in-your-face. They look a little too large and I am not convinced that the contrast of the tabs to the case is better than, say, having aluminium or another silverly metal tabs.
 i am absolutely amazed at your build skills!
 i am absolutely amazed at your build skills!Thanks Andy, yeah took me a while before I knew what's best for what, think my dremel days are soooo goneLooks awesome now.Amazing what you can do with the right tools available
.*drooling*
Fancy making me one?lol shouldn't take you long now you've done it once
hehehe
 Usually after building a case I can easily say I'd be able to re-make 1 but this one I'm not totally sure to be honest lol, I mean I'd know exactly what I'd be in for but still it was a difficult one for sure, only because of the double opposing curve, if it was 1 curve or even just 2 but not opposing I wouldn't have trouble with it, cheers EniGmA1981
 Usually after building a case I can easily say I'd be able to re-make 1 but this one I'm not totally sure to be honest lol, I mean I'd know exactly what I'd be in for but still it was a difficult one for sure, only because of the double opposing curve, if it was 1 curve or even just 2 but not opposing I wouldn't have trouble with it, cheers EniGmA1981  .
.Thanks mate, yeah the learning part & noticing improvement in skill is a really nice part of modding, gonna be weird in a few years but even then I'll have heaps to learn in electronics & motors etcBeen watching this for a while mate. Epic work and dedication to the project. You've had more than a few problems to overcome but then infuriating though it is that's half the fun isn't it.
 the list goes on forever
 the list goes on forever  .
.Thanks John, since brushing the copper pieces they are much more subtle, the stretching tabs I'm going to do something else as I agree they don't compliment the build at all, I even considered making all new tabs with more detail & something to compliment the design but it's difficult coming up with somethinf that looks good & does as good a job as what the plain tabs do but yeah once those stretching tabs have been replaced it should look much more togetherIt is an amazing piece of work, a true labour of love by the look of it.
.This is true but still would be good if I can make it look good as an empty case alsoWas thinking the same thing. But when he has everything in the case then I think it will look totally different.
.Only a couple of parts will be getting painted, the ones that I had to use body filler on, got some plastikote reflective copper paint that I'll try to get around to seeing how it is tomorrow.have you considered more into the painting of it, personally i think you shouldn't bother, i like the unfinished look that its currently got, or you could go for a a thin coating which shows of the grain maybe? definitely worth while spending time on thinking about the painting with a build of such quality, it really looks as if you've given a company a design and they built it for you! top notch mate, keep it upi am absolutely amazed at your build skills!
.Thanks Josh & it gets betterI really like the contrast, the fan grill at the bottom looks particularly good!
	 I got the feeling whenever there was too much copper built up in an area it didn't quite make me smile or it did & then I'd be saying to myself it needs something else so I set about designing a different alu panel to break it up a little & man am I glad I did
 I got the feeling whenever there was too much copper built up in an area it didn't quite make me smile or it did & then I'd be saying to myself it needs something else so I set about designing a different alu panel to break it up a little & man am I glad I did  , been a while since I've cut something nice like this & it's got me hooked on the fretsaw
, been a while since I've cut something nice like this & it's got me hooked on the fretsaw  .
	 :up: & keep em coming
:up: & keep em coming  .
. :up:.
:up:. shouldn't be as difficult there should it?
Oh that's nice, real nice touch man!
To make life easier, you can leave out the double curve on my one, just follow the line of the top straight out to the rearshouldn't be as difficult there should it?
 Thanks EniGmA1981
 Thanks EniGmA1981  .
.Ah cool, so it does fit in well then & it wasn't just me being hyped lolI love the new panel. Very art deco IMHO.
I'm glad you are going to re-work the tabs. If you can make them more subtle I think it will be a lot better.
 thanks John
 thanks John  .
.Mixed opinions about it all round really about the full length tabs so I had a mess around with a couple of concepts that might work, or then again might just waste more time & possibly moneyYou are right, too much copper. And the alu plate for the air vent certainly tone it down abit.
 , thanks SL09
, thanks SL09  .
	 so came up with a couple of alternatives that I think would look better, so let me know what you think, cheers
 so came up with a couple of alternatives that I think would look better, so let me know what you think, cheers  .
