Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Did my car's 20k service today, but front right tyre is down to 3mm, the rest are fine. So might as well change the front two.
The tyre size i need is 205/45/17 W
The dealer (yes, I went to Toyota Dealer
) quoted me £166 for these each, fitted.
http://www.tyre-shopper.co.uk/ts/search/tyredetails.aspx?code=2054517BR1W
alternatively, some brand call Federal for £88 each
He also said if I can get a local indy to give me a quote on the type, they will match it. I can't argue with that. Since they don't stock those tyres, it needs to be ordered in so I am guessing they can order in pretty much any tyre.
What should I be getting, since cost isn't an issue if they will price match an indy, it gives me no reason to go to an indy in this case.
) quoted me £166 for these each, fitted.http://www.tyre-shopper.co.uk/ts/search/tyredetails.aspx?code=2054517BR1W
eek
