Can you give me the email for the CEO please? trying to upgrade to business infinity and this women doesn't know whats going on...
Post 1148 in this thread.
Well I have a reply from the CEO of BT ish.
Something might be done now.
Thank you for your email. I’m sorry to learn that you have problems with gaming with BT Infinity.
Our team will deal with this case. And will look at the problems you’re having. Chris Dunn will give you a call on Wednesday 15th June between 8am and 8pm, let me know if there is a time that won’t be suitable.
Contact us
We’re open Monday to Friday 8am until 8pm, Saturday 8am until 6pm Sunday and Bank Holidays 9am until 6pm you can reach us on 08000280619 with PIN 1823, we can also be contacted by email [email protected]. The reference number for your case is REMOVED BY ME
Best Wishes
Theresa Innes
Team Member – Executive Level Technical Complaints
Telephone Number: 08000280619
Fax Number: 01324 458913
Email: [email protected]
For further information on up to date special offers and also the opportunity to view bills plus so much more please visit our website www.bt.com
How do you know?
Well Infinity is 40Mb and ADSL is probably up to around 20Mb speeds.
You would know as you ar paying for it....
Do a speed test here: http://www.speedtest.net/
I'd assume he's asking how does he know if he can get it?
@Cleeecooo: Go to the Infinity site and put your phone # in.![]()
Thanks. Turns out i'm getting it on the 30th! Yay!
Do BT contact you about it and just upgrade you for free or do you have to sign a new contract etc and pay extra?I'm on the homehub 2, will they give me the new one for free?
Call them and find out about the different options etc..
Tasty ping, what do you get to BBC?
C:\Users\XxXxX>ping www.bbc.co.uk -t
Pinging www.bbc.net.uk [212.58.246.95] with 32 bytes of data:
Reply from 212.58.246.95: bytes=32 time=9ms TTL=55
Reply from 212.58.246.95: bytes=32 time=8ms TTL=55
Ping statistics for 212.58.246.95:
Packets: Sent = 26, Received = 26, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 8ms, Maximum = 9ms, Average = 8ms
Control-C
Code:C:\Users\XxXxX>ping www.bbc.co.uk -t Pinging www.bbc.net.uk [212.58.246.95] with 32 bytes of data: Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=8ms TTL=55 Reply from 212.58.246.95: bytes=32 time=8ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=8ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=8ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=8ms TTL=55 Reply from 212.58.246.95: bytes=32 time=8ms TTL=55 Reply from 212.58.246.95: bytes=32 time=8ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Reply from 212.58.246.95: bytes=32 time=9ms TTL=55 Ping statistics for 212.58.246.95: Packets: Sent = 26, Received = 26, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 8ms, Maximum = 9ms, Average = 8ms Control-C
After a turn off, turn on of the equipemt and click of the connect button in the home hub, speeds are back, but wierdly, and it is ALWAYS the same, the broadband light turns off after a few minuites needing another turn off and on again, and then the hub goes in to a sleep state, requireing another turn of and on (3 times now and alwast 3 times) before it stays on, untill the next time the speeds drop.
Current speeds now:
