It didn't seem worth starting a new thread and people were already talking about llano in here. Anyway with nothing new released about bulldozer this thread would die without llano![]()
Not at all people would find something to argue about.
with no information about BD being public knowledge yet people are speculating as a result of the known Llano info. its more of an AM3+ thread now i guess.
Is Llano coming out on AM3+? I thought it had a new socket.
It's not the same technology, it's an Athlon II with a very nice IGP attached. Obviously it's more than that due to enhancements in power usage and other optimisations but it's in no way the "same technology".
so why are people banging on about BD being rubbish based on something that is completly different? im proper confused now
Llano isn't much special, just buy a 5570 and athlon II X4 for the same price?![]()
HardOCP is going to preview Bulldozer on the 16th of July:
http://hardforum.com/showthread.php?t=1612784
If AMD were able to bring out chips with performance, you'd figure Llano would also be able to.
Llano's 32nm. I wonder what causes the high TDP of the top two models, the "lesser" options have 45W and 65W and it's still quad-cores, still the same 6550 GPU.Llano's TDP is 100W for the higher model, the 2500k's only 95W...
Is Llano still 45nm?
Llano's 32nm. I wonder what causes the high TDP of the top two models, the "lesser" options have 45W and 65W and it's still quad-cores, still the same 6550 GPU.The GPU frequency on the low-end model is taken down quite a bit though, guessing it's the same for the CPU.
I'm not comparing Llano to SB, I'm just wondering if there's something other than a difference in clock causing the rather large gap in TDP between low-end Llano and the higher-end models as they're all running the same silicon as far as I can tell.The GPU in the LLano is vastly more capable than the one in Sandy Bridge ... it was frequently acheiving 50-200% higher frame rates in tests. Hence the difference. Also, Intel's TDP vis a vis AMD's is misleading. Intel's tends to be best possible case, AMD's worst case. Hence why in battery life tests (particularly under heavy load) the mobile LLanos actually outperformed significantly or matched similar Sandy Bridge stuff. Judging by LLano, AMD's 32nm process is pretty damned good.
