Thanks RaV, i'll check it out![]()
What size do I need to make a picture so it just fits on the single screen.
The phone has a resolution of 800x480, if you wanted to go that extra bit you could take a screenshot on your phone then use the image to make your new one from. That would allow you to factor in your dock bar and status and not lose any of the image when you apply it.
Sorry for a potential stupid question
I'm currently running Jap Jelly 9 on my Gen 1 ZTE blade
Is the above link
Link: http://android.modaco.com/content/zt...-easy-install/
The correct path to follow, i.e I can go straight from Jap Jelly to Cyanogen Mod, or do I have to go back to stock first?
