2.5Gb GTX 570
If i's under 90 days, you can use EVGA step up. Actually, you can't unless you're upgrading to a different GPU.
You can sell it. You're 60 posts away from MM access and Stulid really wants a 570. I suggest you try and reach 250 posts ASAP:p
If the card's $400 dollars in the US, it should work out at around £240 here, then VAT, so around £7,000?
thanks....
how much could i Expect to get for a 570 super clocked card if I do decide to sell it
Bear in mind that the 6950 is a fair bit slower than the GTX570, and ones that are listed as flashable up-to 6970/GTX570 performance are £250 not £200.
OcUK have put them up in price recently from around £200 to £225 and now £250 :eek:
Why would you bother buying one to unlock?
You can buy a proper 6970 for not much more than £250.
To be quite honest im disappointed that im having to even think about getting rid of it. I got the card thinking its not the best but it will do an outstanding job for the next 3 years or so. Then games come out needing over 1280MB.
Don’t get me wrong the 570 is a solid outstanding card but having a bit more MB’s, will make it a perfect card for my needs
It's just the upgradin itch all gamers have :D
