surely a 6950 2GB is a much better and cheaper alternative already![]()
not if using 6 screens. The extra VRAM will help
But under "normal" circumstances, 6950 is easily better for the money
If i's under 90 days, you can use EVGA step up. Actually, you can't unless you're upgrading to a different GPU.
You can sell it. You're 60 posts away from MM access and Stulid really wants a 570. I suggest you try and reach 250 posts ASAP
If the card's $400 dollars in the US, it should work out at around £240 here, then VAT, so around £7,000?
thanks....
how much could i Expect to get for a 570 super clocked card if I do decide to sell it
Bear in mind that the 6950 is a fair bit slower than the GTX570, and ones that are listed as flashable up-to 6970/GTX570 performance are £250 not £200.
thanks....
Stulid might buy it off you if it has a warranty.
Well im thinking of upgrading to 5702.5 if the reviews turn out good
And I can get a reasonable off with my 570
As I said, if you configure your trust, Stulid is pretty desperate to make you an offer.
It depends really. I've ran 3600x1920 from a single card and it's fine for a lot of games. That said, I personally don't mind not using AA...
that maybe so mate but its not even put yet
To be quite honest im disappointed that im having to even think about getting rid of it. I got the card thinking its not the best but it will do an outstanding job for the next 3 years or so. Then games come out needing over 1280MB.
Don’t get me wrong the 570 is a solid outstanding card but having a bit more MB’s, will make it a perfect card for my needs
i know...... its so Frustrating..........
