****The Official Samsung Galaxy S II Thread***
Is there any simple way such as uninstalling a Samsung app to remove the sammy lock screen?
Really annoying when I try to open Go SMS from a message popup and it unlocks widget locker but leaves the sammy lock screen in place, starting to annoy me :mad:
its here, its here
/jumps up and down/
are the batteries charged or do i have to leave it charging for hours ?
Mine was at 65% charge out of the box, started using it straight away.
Sliding to unlock my iPhone 3G was alright but somehow the need to slide the screen to the side to unlock my SGS is beginning to annoy me, can it be turned off?
Turn off the lockscreen? There are apps for that, yeah.
The key to unlocking the SGS2 easily (on the default lockscreen) is to always slide from the edge, not the middle.
Like the new Nokia? :/
You dont need to go from the edge, you can start in the middle (as I do) and just give it a flick (like kinetic scrolling)
Job done :)
Yes. I find the easiest way (and most natural) is when holding the phone in your right hand... your thumb will most naturally swing from the centre of the screen to the top right (9-1 o'clock motion)
