Hey OP, SkScotchegg.
Take the mobo out of the case. Put it on the desk (yep bare wooden desk is fine) and plug the following in:
1: PSU ATX main mobo cable
2: PSU 4/8 pin mobo power cable
3: ONE stick of ram into the relevant correct slot 1 of the mobo or whichever slot the handbook informs you to insert it into when running ONE single memory module
4: The CPU and heatsink. If you can't be bothered to do paste then just rest the heatsink on it for this and use mavity.
5: A single FAN onto the mobo CPU fan header (some mobos require to detect a fan present here to post but this isn't really usually necessary)
6: Use onboard gfx on the mobo and connect to monitor. Ensure monitor is on and can auto detect input or set it manually to DVI/VGA as to what lead you use
DO NOT connect anything else. No HDDs, no optical drives, no case USB or led/power leads at all.
Then take a flat head screwdriver, carefulyl short the two pins positive and negative/ground that would connect to the case's power cable. This should turn the system on.
Post back what happens.
