****The Official Samsung Galaxy S II Thread***
two noob-like questions:
A)- How do i get to sync my google calendar onto the phone?
B)- How do I set a different notification sound for email than one for texts?
thanks.
Since I flashed to 2.3.4, taking a pic is so slow that I'd have to be ready 10mins before "favourable lighting condition" occurred lol
This may have been mentioned before or may even be common knowledge. We all know that by not shutting an app down the right way will leave it running in the background which can be viewed via the home key/Task manager correct?
The only way to shut down the app on this phone is to use the back space key untill you hit the desktop. If you close your apps down like that they wont appear as running in the task manager. Try it for yourself.
Well, judging by the worrying comments of things being slower or GPS not working or whatever, I think I'll stay put with my stock rom 2.3.3 because at least everything works fast, and GPS is unbelievably quick. I remember having to wait between 2 and 10 minutes to get a satellite fix with my HTC Diamond, and only then outdoors, never inside my house. With the SGS2, it gets a fix anywhere in about 5 seconds.
I thnk people should bear in mind 2.3.4 is a leaked version, so perhaps it's not fully optimised.
Killing an app in the Samsung task manager will have the exact same effect. But you shouldn't need to kill/close any apps at all - only rogue apps that you know are killing the battery.
Point is you can stop all your apps you have finished with from running in back ground instead of having to pop into task manager to see what is still running..
