Sorry to ask a question which is completely different to the topic at hand, but I've had my handset for about 2 months now and was wondering what I can do with it. My previous handset was an iPhone 3G and I never really got into the jailbreaking side of things, I did JB it but found Cydia to be a horrible experience which wasn't helped by the limitations of the 3G's hardware so I quickly reverted back to vanilla iOS.
you can install custom roms but from the sounds of it you don't need to, at least just yet any way. imo custom roms took off whilst the older handsets were under powered and android wasn't as powerful as it could be. when i had my htc hero i's put something new on it at least once a month, since owning the sgs2 i haven't really thought about it as it works fine minus a few nicer features i'd like to see such as battery percentage in notification bar.
With this being my first Android handset I know that they are highly customisable and I'd like to try and expand my knowledge on it a bit. There are a few things I'm not happy with and would like to change.
Firstly, is there anywhere that I can get more themes for my SMS conversations?
i don't know about stock messagin app but i use go sms and you can change that in so many ways, there is even a theme called iphone theme
i don't like it however you can have many different styles,colours etc.
Secondly is Swype worth sticking with?
i didn't, instead i downloaded official gingerbread keyboard from market place
Also there's one other thing which probably sounds stupid but I'm struggling to find anywhere that has decent quality wallpapers for my SGS2.
try googling for android wallpapers. there are loads.the trboule you have is you can have static wallpapers or ones that move when you scroll so it's hard to get the right dimensions for both types.
The standard icons are a bit boring and I downloaded GO Launcher EX which made the icons sort of glassy but they still look quite horrible.
i use go launcher and like the icons, but if you don't then just simply hold your finger on the icon you don't like and then select change icon. you'll off course need one to replace with but again a quick google should give plenty results
One other thing I've noticed is that some of the better rated apps seem to be developed by Chinese companies and as a result the instructions have quite bad English. Is this something that's quite common or have I just installed crap? I'm mainly talking about GO Launcher and the HD Wallpapers one.
prob just bad luck. i never struggle to read description.
