- 22 Aug 2010
- In My Command Center
sorry to be blunt, which is better out of the above?
many thanks
many thanks
6 is higher than 3.
Did you mean SATA 3Gbps vs 6Gbps?
If so, then for a mechanical HDD, it makes no difference whatsoever. For an SSD on the other hand, you are opened up to much higher read and write speeds. SATAII or SATA 3Gbps is limited to speeds of 300Mbps.
SATA 3 is 6Gbps.
They are one and the same thing.
Perhaps you should be asking a different question.
i was refuring to ssd's that say sata III and others that say sata 6Gbps i just wanted to know the difference, thankyou for all your answers![]()
So when i'm looking to replace my 500GB HDD for one with a larger volume, are you saying there isn't much point in buying a SATA III one over a SATA II one??
My Mobo supports SATA III, and i'm using an SSD (60GB vertex 2) as my boot drive but I need more storage space. I was looking at the WD 2TB drive, the SATA III is another £5 over the SATA II.
sata III 6gb/s is better.
