****The Official Samsung Galaxy S II Thread***
Had to boot back into recovery (clockwork seems to have dissapeared again...) wiped data/cache in their and now everything appears to be working again.
Now I just need to root it.... :eek::p
This seems like the easiest way to root it following this guide:
http://samsunggalaxysforums.com/showthread.php/4563-root-the-Galaxy-S-II-via-SuperOneClick
But I'm wondering will the XWKDD kernel used in that guide work for my phone even though my Kernel version is BOKF3? I think this is the issue I had yesterday, couldn't root it because their didn't seem to be a BOKF3 kernel.
Cheers
OK so get unsecure XWKDD, Flash with Odin once booted use superoneclick to root, then flash back to normal kernel & check with root checker app you are rooted.
That is the method I did when I wanted to keep stock & root. Do you not have BOKF3 stock kernel? What kernel did you just flash?
Having my SGS2 replaced tomorrow as the mic quality is really bad, tried different ROMs, radios, everything. Definitely something wrong with it.
Yeah I do have the BOKF3 Kernel, it's just that guide was telling me to download and use XWKDD kernel.
I will flash with XWKDD kernel then and when it's all done flash back to the BOKF3 kernel.
Will give it a go now, cheers.
Cheers! I finished using SuperOneClick, flashed back to my stock Kernel, ran root checker and it said I had root access.
So now I believe that is finally everything done and I'm back to normal?
Cheers
Cheers
Yep check in Phone settings & make sure everything is BOKF3 :)
I'm just double checking now, baseband is I9100BOKF1 whereas Kernel is BOKF3, hmm? Is that normal?
EDIT - just seen my previous post from last night before I even touched the firmware and they both match. All sorted then. :)
Going freeze a ton of useless apps now!
All share
Analog clock
Android live wallpapers
Ap Mobile
Bookstore
Buddies now
chocoEUKor
com.orange.authentication.simcard.permission
com.sec.android.app.lcdtest
com.sec.android.app.screencapture
com.sec.android.widgetapp.weatherclock
DataCreate
Days 1.0
Digital clock
Dlna
Dual clock
Email 1.0
Email widget
EncryptApp
EncryptApp
Error
Factory test
Factory Test
FTC
FTM
FTS
Gallery 3d
Game HubHome screen tipsKobo
Genie
Gmail
Google feedback (May cause issues with Market??)
Google Partner Setup
Hel Neue
Image Editor
IMEITracker (is this the samsung tracking app?)
Installflash
Kies air
Kies via Wifi
Kobo
Let's try panning
Live wallpapers
LogsProvider
Maps
Memo
Microbes
Mini Diary
Mini paper
Minidiary
Mobile printMusic Hub
Mobileprint
MobileTracker
Mtp app (For kies)
Musiccodp
News and Weather
Ocean weather 1.0
PCWDevice
PhoneUtil
Polaris
Polaris office
PopupuiReceiver
Post It
Preconfig
PressReader
Pressreader
Program Monitor
Readers Hub
Samsung account
Samsung widgets
Samsungs apps
Secretwalls
Self Test Mode
Serial Number Read/Write
Service mode
Setup Wizard
Setup wizard
Share App
Shareapp
SNS 1.5
Sns disclaimer
SNS image cache
Sns Twitter
SnsAccountFB
SNSAccountMs
SNSAccountTw
Social hub
Social Hub 2.xxx
Social Hub 7.52xxx
Soundplayer (Buggy)
Speech recorder
STK
Street
Suggests
Swype
SyncmIDS
Talk
Task 1.0Trim App
Tasks
Touchwiz
Trim app
TW apps (wallpapers etc)
TwWallpaper chooser
Video editor
Video makerYahoo Finance
Voice recorder
Voice search
Voice to go
Wi-Fi sharing (only needed for hotspot?)
wipeoutreceiver
wlantest
wssyncmlnps
Youtube
Zinio Reader
Taken from
If everything is working fine I'd imagine it'll be ok. I can't really give out too much advice only what I've gathered in the last month.
The other guys here are so much more clued in than me :)
How do you change it so that when you plug your phone in, it goes straight to USB mode without asking you first? It always went straight to USB mode on my first stock rom but since changing to a different one and changing back to stock I always need to manually select USB Mode.
Cheers
Right, picked up a mint unlocked SGS2 for £337 which should be delivered in a day or two along with a couple of cases or screen protectors. Saved myself a fair buck by waiting a month and buying a second hand one, so actually quite pleased!
Cheers
Menu --> Settings --> Applications --> Development --> Tick 'USB Debugging'
