Man of Honour
- 5 Jun 2003
- Falling...
They are bloody hard!
I literally can't do overhead squats, shoulders still slightly restricted so I just fall over in a super manly way![]()
I'll video an attempt when my brother is back.
...but to be clear, I said super manly![]()
In preparation for using my shoulders, I do the following:
- some gentle internal/external rotation stretching
- lacrosse ball in my pec and anterior compartment of my shoulder (hurts like a blowtorch, but it works)
- foam roll my thoracic spine.
- warm up for each specific exercise with light weight. For bench, I always start with just the bar for 15 reps.
Then it's just a matter of always being conscious of retracting my shoulders back in their sockets when pushing.
I'll let your judge for yourselfSuper manly, or Superman-ly?
(you lose tension in your back and your shoulder blades are no longer pinned, shoulders come off the bench). Also, it isn't just about having your shoulders pulled back, you also need to pull them down to your feet.
Just ordered some 80% whey from MyProtein (Iron Science delivery was going to be £16!)... I was just wondering, is it better to take pre or post-workout (or both)? Particularly for cardio I'm guessing pre-workout might be better as it'll stop my body trying to use muscle for energy?
Can I ask, where do you train?
the guy next to me was doing something crazy like 40kg probably more! :0
2) The pad is a real problem and will do you more harm than good. In your case it's exaggerating the problem you have with your back, by having the bar even higher up your spine you are increasing the forces on your back. This means that when your spine is out of position and becomes loaded your back muscles have to work very hard to stabilise. A partial fix here is to make sure you push your chest out throughout the lift.
Also, you mention shoulder flexibility restricting your bar position. Try this: http://www.mobilitywod.com/2011/04/episode-211365-the-simple-five-way-shoulder.html
Eat a solid meal about an hour, hour and a half before your workout. Something with carbs for energy and protein obviously.
Avoid fats pre and post workout, especially post workout as it slows the absorption rate during that crucial time![]()
Ahhhh. Don't you love high rep day![]()
High reps with 40kg+ dumbells?I can't even imagine getting there, even 25 is a big ask from where I am.
