- 27 Mar 2004
- Between Realities
Because it out performs the Phenom... =\
In what exactly? I would guess that anything using four cores would be considerably faster on the AMD CPU. And as more and more software is using 4 cores these days it only makes sense to go for a quad.
^Its still faster.
And you need to get to the speeds of a 980BE(3.7GHZ) to match a i3 2100, while generating a lot more heat and consuming a lot more power
http://www.anandtech.com/show/4083/...core-i7-2600k-i5-2500k-core-i3-2100-tested/20
As you can see the i3 2100 humiliates the Phenom 975BE in these tests, perhaps even getting to 3.7ghz wouldnt be enough as the i3 is so far ahead.
I'm not quite sure why you'd want a dual core CPU these days?
and the i3 2100 is now down to £85.
Because its faster than even a quad coreand the i3 2100 is now down to £85.
What happens when the PhenomII X4 isnt processing multi threaded applications and games that only use 1-2 cores? it ends up even slower again
After a lot of thought, quad is for me and the Athlon quad is enough for my needs
Is the correct decision. Get a 955 Phenom II for £85. Nothing else comes close in this price bracket.
(All info available IN THIS ACTUAL THREAD)
?You guys realise the dual core has HT right (One's against the SB 2100)? So it's 4 threads versus 4 threads right =D?
I just find it confusing...I need it explaining!?
Surely its better to buy the overall better performer!?
The SB 2100 cant handle 4 full threads or it would be called a Quad core.
Half the time I can't tell if you're trolling...
