- 13 Jan 2004
- South East
it is not a cheat and it just helps run the game at optimum .
why you think fps games are called this![]()
Because it stands for 'First Person Shooter'
'Cos why should they? If they can get an advantage so be it.
Every FPS I play I turn down/off the settings to the point that I can see players a lot better.
I thought all that guff went out with the old Quake engines, good old magic FPS numbers, 125/333 etc.
- MSI GeForce GTX 570 1280MB (Overclocked)
- AMD Athlon II X3 425 - Unlockable to AMD Phenom II B25 (Already Installed)
- Kingston HyperX Genesis Grey 8GB (2x4GB)
Yeh I used to get 250 constant with my 4850, so you should be fine.
To all the noobs and naysayers: This isn't cheating, the Q3 engine works best at certain frame-rates, meaning you can run faster, game feels smoother etc.
If you'd actually played any competitive shooter then you'd know why getting a high FPS is important, be it cod4, CSS...
Rubbish, frame rate exploits have been part of quake engined games for years and years and years and are generally accepted in competitive play.
Implying it leads to wallhacking etc. is absurd.
Accepted because they can't prevent them or accepted because they're not exploits? Yeah I thought it was cos they couldn't prevent them too.
surely anything above steady monitor refresh in css is pretty pointless 250 is certainly a complete waste in css
Exploiting is still a sub set of cheating. So no I don't see it as absurd that someone desperate to get any advantage they can will eventually stoop to actual cheating. Along the way they'll probably try out scripts and config changes and altering models and decide its just not enough...
When you play a game for such a long time and at a competitive level you'd do anything to get an advantage.
Also the way you are talking it's like: "Exploiting high FPS one minute, aimbots and wall-hacks the next..."
It's pretty clear now what is hacking and what isn't. People play at LANs, record demos etc... It's obvious when there is more than just using the game configs to their potential.
And its curious how people inclined to abuse the game with scripts seem to be the ones that are more likely to hack so no that statement is not unfounded.
I'd rather play something looking the best it can and die more rather than it looking like the first Tekken game and getting better scores. Unless I'm completely out of the loop and women get turned on by your K/D ratio now?
I'm arguing that lowering your visual settings in order to achieve a high FPS and to remove visual clutter is perfectly fine.
Not quite ... let's rephrase that ...
'... lowering your visual settings in order to achieve a high FPS in order to exploit bugs and glitches in the game '
No, it'll only do 249.99 fps, unlucky.
this has been a really interesting thread, i had NO idea that increasing the FPS could lead to higher jumps/ better weapons etc
