- 22 Mar 2009
I just placed an order H100 watch this space shortly
will going to fit this into the back rear of 2 x 120mm fans on my antec 1200 case.
We could do with some tests with decent fans and decent paste and a little list of cases this would fit unless corsair already have a list.
I not long brought a Cooler Master CM-690 II. i got this H100 yesterday to go into the case.
But as i got a Asus Rampage III Extrem, this water cooler kit wont fit grrrrrrrrrrr.
Can't believe itnow im buggerd.. have to sell the case now and get something else!
Hey there,
got my H100 yesterday. I managed to mount it in my Define R3 but it was a pain in the ass.Unfortunately 2 of the fan headers seem to be broken. The third and forth fans are on full speed for the first 5 seconds while booting, as are the other two fans, and then stop until I set the Corsair to the middle or highest level and tap the fans manually. *sigh*
Any suggestions? I tried both the stockfans and the apaches btw.
Edit: Okay now it's completely ****ed up. After switching the fans a couple of times I ended up with the left headers still not working properly and the right headers forcing the fans to go max speed. I'll get a new one next week...
Gonna be truthfully honest with that question. It's because I ordered at 2:30am and yellow and black aparently look the same to me... haha. I'm going to send the Apaches back and use the 4 Vipers if I can devise a way to mount it in the HAF-X without having to loose the 2 200mm top fans.
It's the board mate!!Is your motherboard the issue or the case? I ask because I'm looking to get that cooler and possibly that case! thanks.
If you got the Asus Rampage III it won't fit!! as the fans hit one the the heatsinks. unless u really bodge the case to fit.Why doesn't it fit?
EDIT: Just looked at the size of the radiator on the H100 and it's generally slightly smaller than an XSPC RS240 radiator, which myself and quite a few others have fitted in the top of the CoolerMaster 690 II, so the H100 should fit.
If you got the Asus Rampage III it won't fit!! as the fans hit one the the heatsinks. unless u really bodge the case to fit.![]()
Oh, are you trying to fit 4 fans in a push/pull config? In that case, yeah you need a better case (or at least bigger).
If you're only using 2 fans then the idea with the CM 690 II is that the rad goes in the top of the case and the fans go in a pull config on top of the rad but outside of the metal case frame under plastic top with the mesh grill on it. I think it mention/explains/shows this in the 690 II manual.
I've not used the Asus Rampage III though, so there may be somethign else stopping this working too.
Anyone have these running on a d0 920?
Yes me.. @4.2 this chip still a cracking chip
The water cooler is very nice... look good too..
