- 21 Oct 2009
That's great, cheers. Thanks for taking the time to sum it up! I think I was on the right lines already, just wasn't sure of the details.
No problem
Weird, atleast it's all working now though.
I don't know if you're new to Android or not (my memory is terrible at remembering who's who, never mind what each posters experience with Android is), if you're not or if you already know about the following feel free to ignore as I don't mean to sound patronising
Obviously make a backup in CWM of your ROM (I think I remember you saying you were going to do this) so that should anything happen in the future when flashing you have a working backup to go back to.
Download "Titanium Backup * root" and once you've installed all your apps and setup all the settings how you want do a backup of everything, so that if you need to factory reset for whatever reason you can restore everything, you can choose individual stuff to restore/backup so if you get a new ROM and don't want the old theme or whatever put on you can just not restore that (I normally just restore contacts/accounts and sync/all my games and apps along with the data for them to restore all my settings and game saves).
Apologies if you're not a noob to Android like me and that the whole post was obvious **** that you already knew.
Hmm, my phone is being even more annoying now, bugging out when I try to go to any part of the message other than where I've currently typed to, deleting/adding stuff at the end of the post evem though the curser isn't there.
Hmm the above bug is gone now that I've gone out and back into the post box, might have something to do with the text you type not actually staying there when you press done the first time opening the box up. Still, atleast copy/paste works since I always forget to open and close it straight away.
im on lite'ning 5.0 and its fine. so what if it artifacts, it seems there are issues with the crt off animation using certain combinations of rom and kernal. Hardly a big deal when nothing else is affected.
Yeah it doesn't bother me & it happens on Exynos 3.4. I think I might try Lite'ning Rom again this weekend. What kernel are people using on this? or does it install one when its flashing?
Hi just updated to lightning 5.0 and get yellow triangle on boot up but clears - seems ok after wards though - can I clear it? ta
edit - just means custom rom installed I gather - no big deal...
Anyone got a link to a stock ROM? I've installed Litening and it's looping![]()
You can clear it if you flash a stock kernel, I believe![]()
I flashed this stock KE7 when mine was looping:
http://www.multiupload.com/IBRBHDUDXI
It'll still loop after you've flashed that until you boot back into recovery and do a wipe, then it'll boot![]()
Thank you thank you thank you! Bit of a brown pants moment there.
no, no issues here moggsy
