- 14 Apr 2010
- swanley,kent
corsair have just released a new firmware for force 3 120/240gb and force gt drives.have a look on the corsair forums
) and a new Os install(more grief from the wife and kids
)it was the newer version so unless i run into any trouble i wont be using the new firmware just yet.
I got the new version too, they are showing the same problems as the previous batch:
http://forum.corsair.com/v3/showthread.php?t=95825
Hopefully you will be one of the lucky ones mate.
I did have one lock up last night so maybe my drive isnt fault free so i'm now contemplating whether or not to update my drive.
I upgraded my firmware earlier ran atto before and after and havent noticed any speed drops.
i have the 60 gb force 3 drive and when i download the 60gb 1.3 firmware file from corsair it only shows 2 folders inside.....1 says 22797_fw_cl_micron_32gb and the other says 22797_mf_mlc_micron_32gb. i tried the fw file and after a minute it failed and lucky it didnt brick the drive but theres obviously something wrong because in the instructions screenshot from corsair there are many many options and not just 2 or am i doing something wrong.....cant get it 2 run at sata 3 speeds on my alienware m17x r3 either was hopeing this would sort that out....can anyone shed some light on this?
!!!WARNING WARNING WARNING!!!
Read the .PDF and look VERY VERY VERY closely at the pictures and read the text on each picture. Be sure to flash with the *****_fw_vic version.
DO NOT FLASH WITH THE *****_mf_vic version or your drive will be unusable!
is your drive on ahci mode in bios
and put it back in the lappy...tried it with atto and its now running 540mb like its supposed to and seems ok
will report back in a couple of days for an update hopefully all is ok now if not im selling it for something else
