Whatsapp is available, battery life with Wifi is bad (at least in my perception as it keeps scanning for networks which drains the battery)
On my old iPhone 3G Wifi was great as it menat much longer battery life but with my SGS2 I keep turning off Wifi as I stop using it, it also wont reconnect to my Wifi network when waking up.
Edit: ^ Screw you sir!
I will have a look at Wifi settings in more detail.
Uhmmm, I can clearly see you were one minute later than meYou replied at the same time as me![]()
If you left on the auto restore feature then apps will auto restore over the air and depending on size could take a while to restore back off the "Cloud".
how come people are using roms when they have features missing because of it? what benefit do they give over losing other parts of the phone?
Is that stock?
Has any one found a rom that wipes the whole phone and installs just android no touch wiz or preloaded cr@p, if so, is it good and is there a how to? I went to lightning 5.0 which I like but feel there maybe better battery gain with a more stripped down rom?
thaks
