The slowest bike build on the internets continues.
Some Blackspire bars. Can't complain for £25.
PS: Supercow - Do you like my strimmer?
Love the frame colour.
You appear yo have matched bright green with bright blue.
Who are you, ichabod?!
You use that thing to trim those ginger Scottish pubes of yours?
To be fair the exteme kerb gnar while nipping down to the shops isn't the most demanding of any pedal.My last superstar pedals lasted 2 years and showed no signs of dying
To be fair the exteme kerb gnar while nipping down to the shops isn't the most demanding of any pedal.![]()
And they would still look out of place. Get some DMR Vaults or Pre-runners or such like. They would finish off your build nicely.Maybe I'll scratch off the white Superstar logo and put on it " Kona Wah wah" or " Nukeproof" etc etc on it... because they are all made by HT.
Why bother doing that when the Superstars are working perfectly fine for Mr Cow. Brand snobbery is lame. Support the underdog imho.
Not gonna happen, I love these pedals, they grip and they last. I'd love the Point1 pedals, or even the DMR ... but these are fantastic for a fraction of the price.
Meh
You do know they are made in Asia? and are not exactly an underdog.
I should add, that if in fact these turn out to be a bad batch, then I'd most likely feel burnt and try the posher brand pedals.
