Anyone use switchpro? It annoys me that the LED toggle doesn't work on it, are there any decent alternatives?
Mine was unlocked and unbranded from dialaphone.
I use it and the led toggle works for me
Wonder why mine doesn'tWidgetsoid makes my LED go on/off like switchpro used to on my Desire but on this it just makes the screen white, which is naff!
Any idea how to change the 5 drop down icons from the task bar at the top (unsure if it's a stock or lite'ning feature)?
on switchpro go to global settings and tick 'use camera flash'
And I don't think you can change the drop down switches.
i'd say pay as you goIs it better to go pay as you go, or contract, if I will mainly be just using the mobile web and wifi and not texts or calls?
got my S II sim free for £499
For those that missed it last time, the mobiles.co.uk £99 deal on the Samsung Galaxy S2 is back. This is a 12 month contract and includes 400 minutes, 1000 texts and 1GB internet for £30/month. So that's a total cost of £459.99 for the phone together with the contract.
Did you just click the test button or manually select a server and are both phones on the same network?
Those are 2 important things to make sure are the same on both phones.
i didn't pay for the handset upfront . im paying monthly to a catalogueit largely depends on usage. over the course of 24 months mine works out at about £720 but thats on a contract, so minutes/texts/internet included. PAYG wouldnt work out any cheaper in my case and of course id have to pay for the handset upfront as well, which isnt the case for a contract (other than a nominal fee in some cases)
White Galaxy S2
http://www.mobilefun.co.uk/sim-free-samsung-galaxy-s2-i9100-16gb-white-p31236.htm
Sorry if linking is not allowed![]()
Not usually a fan of white phones myself but have to say that looks very nice and would def prefer to my black if given the choice now.
yes the phone would be yours...Just found this deal on HotUKdeals:
Sound like a good deal? Says its on talkmobile. Also one poster mentions that after the 12 months are up it can be used with a simcard and used as a PAYG phone, is this correct?
