DLSR for £500 (Must have good recording)
OcUK Staff
12 Apr 2008
OcUK HQ
I was looking at video recorders and changed my mind to go for a DLSR which has functions to record HD film, I am more interested in the film side of it, but I would be hitting 2 birds with 1 stone by being able to take photos too which is something else I want to do.
My budget is £500 what is the best out there for that price? - I will be getting a tripod, maybe lenses too if recommended, and attachments etc.
Hope someone can help. :)
Ah, I am liking the 600D, I like the flip out screen, does that mean I could put it on a tripod and view myself through the screen? Does it rotate towards to subject?
Yes and the D5100 also has the same functionality in that respect.
The only issue I have with my D5100 on full HD recording is that the autofocus is loud enough to be heard in the movie your recording, meaning manual focus only to avoid the excessive noise.
Have you experienced any of this?
I ask because the last time this came up on another forum somebody seemed quite worried about it, although i haven't heard it as a complaint at all. Nor can i see the effect in any Pentax K-r footage i've found. Just musing about the pros and cons of CMOS and CCD for video...
Oh, and 5UB - since you're buying a complete kit it would be useful to know what you're actually videoing? If you 'require' sound then it might be worth going used to get the best value for money with regards to an external mic as well as a few lenses and a tripod.
I'll record something now and check that out for you
I will be filming outside/inside, of myself performing magic, most will be visual with no sound, but I may do some magic towards the camera while talking too. - I will need a tripod definitely, SD cards, and the camera. I can always get lenses afterwards, and other bits I guess unless you can think of crucial things I may need.
Okay just took a 20 second or so video of outside my room and moved at the same speed as that video, plus faster and slower also. Absolutely no sign of that at all mate. Quality is really good also :)
I dont think any camera is capable of recording longer than 10mins, so if your magic show lasts for longer than that then the rabbit may not be seen coming out the hat?
The D5100 can do movies up to 4GB and 20 mins long per clip, the total duration dependent on the memory card size.
RedSnapper have probably the cheapest tripods worth bothering with... i mean, i have a hama one that works for most of what i need it for, but i got it for free so it doesn't really count :p
I would say so, if not I can learn. :)
I have been looking at the Canon 550D, it looks great.
I think you can get special focus tools to put in the viewfinder to help with focusing.
Personally I found Manual focus very difficult on the 550D, largely because the viewfinder is soo small, which makes it a little difficult to tell when you got focus spot on.
I don't know why they don't use Split Prisms, simply because of that my ST605n is infinitely better than any other camera i've even touched (well, it was before i decided to try to take it apart ;) ). Hell, it's practically easier than Auto-Focus.
