- 17 Jun 2009
- Swansea
Stupid question.... my case is stinking with dust.... recon i could use the hoover in there a little or not?
Still use the hoover but keep the hose at a distance so when the compressed air blows the dust out the suction from the hoover sucks the blasted dust away otherwise all you're doing is moving the dust to other areas of the case which is a pointless exercise.
There's not really anywhere else to put them without them getting in the way! Corsair GFX power cables are pretty fat! Still, a bit of looping helped![]()
Let me tell you this, my Lian-Li was easy to do this. The 650D? Whoah it's heavy. I'm fairly good with lifting heavy stuff but this is something you need 110% focus on lol.
The front panel is aluminium but the rest is steel yes. High quality steel though nonetheless. Unlike Fractal's XL Define I had briefly...
Looks good dude. Can't think whats next to change on thatHere's my contribution, finally happy with it after 3 different cases and gfx cards etc in the past 12 months, although tempted swapping out the 240 rad in the front for a 360 as have the space
SNIP
