- 16 May 2005
- Manchester
Was he vouched for, or?
He was by Khrest (his father). I've spoken with Khrest about it before I took this action, which Khrest agreed with.
Because moving a few small areas/builds ruins the entire map for everyone... riiight. It makes absolutely no sense to wipe everyone's builds when there are people who would be happy to help move them over. Only those build areas will be left with the old landscape and if the people occupying the builds are OK with that then who really cares?
It puts players who don't have their builds moved at a disadvantage? Give me a break, if you'd put loads of your time and effort into building something in the first place you'd get it moved over anyway. Of course you're not gonna care about the map getting wiped, but many of us do.
. If not i will send them again.
When there is a wipe (it's going to come at some point probably November-December time) I'll be sure to host a backup of the map along with some schematics as I'm going to be saving my builds at least!![]()
Right, so there is no point trying to convince you otherwise as you seem set on not changing the map. Seems I'll be stuck to singeplayer when 1.8 comes out then, and wait for the map to be changed![]()
Couldn't you guys just have a seperate world? Not a server, but a world with portals to and from? That way you get to keep the awesome builds and you get a brand new world for the new features.
This falls under the earlier post you made about judging something before it has happened. Once 1.8 is out we'll regenerate the unstable lands and *then* evaluate it.
We don't know how much difference it's going to make at the moment because we've not actually seen it. We can guess based on all the stuff they've posted but that's not the same as actually seeing it in action.
I cannot build in the unstable lands and one of my plans was to build a small river village. I cannot do that, so I will not play on the server. Nor will I be able to act out my other plans. So when I can act out these plans I will resume playing actively on the server.
I am not judging before trying it, because by doing this you have effectively set limits to what I can do so I decided to remove these limits by playing on single player until you lift these limits. If you have a problem with me deciding to stop playing on your server actively, then please tell me.
Wouldn't a 2nd world increase your RAM overheads a lot? I meant to ask how much RAM that test server used (as a RAM Drive).
Well if a creative mode is apparently going to be added in 1.8, why not have a creative portion of the map?
Technically no. Dont forget a server does not run entire maps at a time only chunks that people are around. OFC there may be a slight performance hit as it wil have to load data from two maps but it should not be very noticeable.
Looking at the way the server has been running lately(fantastic unless an admin is online) also when the test server was running (i assume this was run on the same server as the main one) when they set of insanely stupid amounts of tnt not even a glitch occurred on the primary map.
So, we could actually have a workaround by having 2 maps going? I'm sure more people would donate if we had to...I, for one, intend to when I've got some money, which should be soon haha!
