- 26 Aug 2003
Over 34 miles today, quite pleased with oneself. I just plan to keep upping it bit by bit.
[DOD]Asprilla;19908089 said:I don't know anyone who has a good thing to say about slime tubes in a road bike. However, I find them to be excellent on the push chair.
Re; tyre pressure. It's a tough one. Too low and you are likely to get pinch punctures but too high and you are likely to get pointy thing punctures. I tend to aim for 110ps, but then me plus bike plus rucksack is only 85-90kg.
How often do you get punctures?
[DOD]Asprilla;19909038 said:I'm not answering that question; it's a sure fire way to attract the attention of the puncture fairy.
Put it this way, I'm changing a tyre before I go home tonight because I've worn though the rubber and down to the threads (a particularly impressive emergency skid last night signalled the death knell for this tyre) and it will be the first time I'll have had this tyre off since I put it on.
Durano S tyres are my weapon of choice, but I'm having to put a Grand Prix 4 Seasons on tonight because no where round work stocks the Duranos.
The Allez is pretty much was it say on the tin - cheap, fast and reliable. The Secteur is more comfortable with a longer wheel base & longer headtube so it's a more relaxed position.Hi guys,
Do any of you ride a Specialized Allez? I'm thinking of getting one to get into road riding with a friend of mine and just wanted a first-hand account of it. Reviews seem solid for it but just want to double check![]()
