You're not far away from me, where did you source your touchpad?
Also got any spare?![]()
Heh got lucky on the Comet site, sadly I only ordered one
No need to press the home button, simply swipe up from the bottom bezel quickly to get your cards.Press home button then flick them upwards off the screen
you can, go into pictures and bottom right, set wallpaper
No you can't.![]()
You don't need to press the home button do the same in card view to open the apps menu, swipe up from the bottom border into main screen to go to card view. And you can close apps by swiping the card down to the borde as well as up.
with picture selected and being viewed click far right button (3 lines with a down arrow) you can then click set as wallpaper
I had £25 voucher on my account from CPW when they didn't honour the iPad deal (anyone remember that fiasco?) and the touchstone+case were already reduced to £35 and £17.50 respectively. They've currently got the 3 for 2 offer on all accessories so I got the case for £14.99 (correction) for free.^
Good god where from?
I'm having a quiet awesome week.
Just picked up the touchstone, touchpad case and because there's a 3 for 2 offer on accessories, a free £10 case for my desire HD all 3 for a grand sum of £27.50![]()
You don't need to press the home button, swipe up from the bottom border into main screen to go to card view. And you can close apps by swiping the card down to the borde as well as up.
I can't get this to workYou don't need to press the home button, swipe up from the bottom border into main screen to go to card view.
You are indeed lucky, I took the last ones off the shelf too! One of eachPicking up my touchstone tomorrow from cpw. No case however, according to a rep I was one of the last to get the dock and I should consider myself lucky as it is.
On a side note, does anyone gave any issues with jumping/moving text while typing on the forums?
