***The Official HP TouchPad Thread***
Quick Tip:
Do you have your cards stacked? i.e. multiple internet cards all together? Do you want them separated as separate cards?
Simply make sure it is in card view and then press and hold on the card until it turns grey. You can then (while still holding) move the card about as you wish.
Another quick tip.
Customise the launcher bar
Press home button until your app list is displayed.
Press and hold the app icon you want to remove from bottom launcher bar and drag it off. You can now press and hold on any app/download/setting and drag it onto the launcher bar.
You can not have more than 5 apps on the launcher bar (6th one you cant remove)
I'm having a quiet awesome week.
Just picked up the touchstone, touchpad case and because there's a 3 for 2 offer on accessories, a free £10 case for my desire HD all 3 for a grand sum of £27.50 :D
Press home button then flick them upwards off the screen
You don't need to press the home button, swipe up from the bottom border into main screen to go to card view. And you can close apps by swiping the card down to the borde as well as up.
You don't need to press the home button do the same in card view to open the apps menu, swipe up from the bottom border into main screen to go to card view. And you can close apps by swiping the card down to the borde as well as up.
If you turn the tablet upside down when in card view, you can pull them down and release them for some Angry Birds fun :)
Errr where from?!?!!!!!!!! :eek:
with picture selected and being viewed click far right button (3 lines with a down arrow) you can then click set as wallpaper
Hmm I might be, being thick. Will check again when it does the system update.
Good god where from?
I had £25 voucher on my account from CPW when they didn't honour the iPad deal (anyone remember that fiasco?) and the touchstone+case were already reduced to £35 and £17.50 respectively. They've currently got the 3 for 2 offer on all accessories so I got the case for £14.99 (correction) for free.
Super awesome or what? :D
So if you guys still have your £25 voucher floating around - Gogogogo!
Oh thought you had some sneaky deal up your sleeve then! No vouchers handy for me. :( Would love a TouchStone to go with this.
It's there after the update now, but the picture isn't full screen. There is a massive border around them when I set them as my wallpaper. :(
True but people seem to be having trouble with this so they might find it easier to use the home button
Picking up my touchstone tomorrow from cpw. No case however, according to a rep I was one of the last to get the dock and I should consider myself lucky as it is.
On a side note, does anyone gave any issues with jumping/moving text while typing on the forums?
You are indeed lucky, I took the last ones off the shelf too! One of each :cool:
Do you mean by typing physically? I can't report on that as I'm using a bt keyboard.
