Take the hintJusteat doesn't work on the default browser![]()
MASSIVE LOL from me and mrs Steinooo! http://hewlett-packard.org.uk/ try to add to cart......
Take the hint![]()
Mail > Email Account > fill it in...![]()
I picked one up in Comet for £20 tonight, wasn't sure at first but its nice as it is very snug and the folding front cover acts well as a stand.Right I'm getting a case for this, fingerprints driving me insane on the back. Official one generally considered a good buy?
OK, so may have found a bug in the email client, it wouldn't take my password, it was 17 characters long, included 5 numbers and 3 upper case letters, apparently that is too complicated......
Really desperate for Spotify on this, quite annoyed considering it is available for the Pre![]()
Skype video quality is awful, sounds is fine.
Anyone else find that TVCatchup lags badly even on low quality? Have to use m.tvcatchup.com but the quality is a bit too low.
m.tvcatchup.com only loads up a video screen like its trying to load it but never does.
You need to update the webOS software, mine did that but works fine after the update.
(settings/system updates)
Has anyone successfully logged into the hotmail through the web browser? Hotmail just has some sort of problem
On the plus side, overclocking to 1.7ghz makes a massive impact as do the Preware patches. Massively recommended.
