You can get homebrew apps by installing Preware, follow this guide to install it and install the speed tweaks which really speeds things up and takes away a few of the annoyances.
Ouch, so after doing more searching it appears that there really is no way of moving the text cursor other than tapping a dozen times hoping it eventually places it in exactly the right position. Crazy.
Mine should be arriving tomorrow. Fingers crossed.
Not sure if I should buy the Touchstone or not, it sounds pretty cool but for £35..is it worth the money?
Also hows the flash player? Anyone know if you can use Fifa Ultimate Team webpage on it? That's one thing that bugs me about my iPad 2, no flash player for Ultimate Team!
I don't get the Box app, what's the point of having 50GB storage if everything you put on "the cloud" needs to be downloaded and saved onto the touchpad? I thought it streamed the content?
