I can 100% confirm that Pinapp multiworld plugin is the cause of the instant kill fire. Tested with 3 dif Bukkit versions with only this mod on 2 dif servers = same result that we are seeing after entering a portal fire = instant kill.
Nice work!
I think that plugin is the least used so pretty good it was that causing it.
Been doing some testing with multiverse. Took me about 5 mins to set it up. No fire bugs. Portal worked fine also no disappearing blocks ect on entry/exit. ps also compatible with world edit. Also when you step into a portal its faster than Pinapp. Multiverse has an addon that can scale the size of the nether so this could fix the nether issue.
I can't get on the server, plus the chat on linktart is only working one way again. This time people in-game can't see messages from the website
Could you please add spawn_uk to the whitelist please? He's a friend of mine and as I love this server it'll be great to get my friend on here![]()
Would it be possible for my gf to be added to the whitelist? Would she need to be an OcUK member?
So once shes all signed up have her post her details on this thread and sign up to linktart.co.uk, then I'll be able to whitelist her.I don't know much about modding etc. but one thing I thought might be useful would be a feature whereby holding a torch in your hand causes the same amount of light to spread around the player in the same way as if you 'planted' the torch on the ground.
I find an awful lot of caves and I rekon it would be pretty athmospheric to be wandering around with a torch in your hand rather than having to put them down every so often...
Is this possible?
I've used multiverse before and it caused issues (different ones to Pinapp and potentially less bad).
My main concern is about players having to use commands to set up portals. I'll check up on multiverse to see if this is an issue or not.
Why not just have 1 portal at the spawn? Everyone has access to /spawn. This saves messing around with the portals and could save possible hassle in future. Could you imagine the problems that could occur is some1 was to build a portal that spawned on some1 else build in the other world?
I've actually just put TorchLight on the server for testing - it's basically the same but updated for latest Bukkit.
. I am only just starting to learn java myself so limited knowledge on how it works.
