- 1 Jun 2010
- Bedford
I am awaiting contact & pressure paper(s) so I can optimize contact in one go and don't have to keep taking apart my PC. I have some Zalman ZM-STG2 thermal compound aswell which I can use to see how the pattern is turning out and posting pics here,before actually using the papers.
This will also be useful when comparing the IC Diamond pattern which I am using as it has been about 2 weeks now since my last post although both compounds have different density/viscosity.
As I am also approaching my final testing I would want to make sure that my last testing is as accurate as possible hence there are still some factors which I need to discuss before actually carrying out the testing.
I am thinking about my previous tests as a stepping stone and as a learning experience for myself in that some mistakes were pointed out and yielded some further understanding about the whole process from an end user.
However I am surprised the thread has gone quiet now.
) and I've done some testing! All temperatures are measured as degrees above ambient temperature during the test, ran Prime95 for 30 minutes with the highest temperatures recorded by Realtemp being used.
