- 17 Aug 2003
- Woburn Sand Dunes
other firmwares are also flashed with odin and you do not need to root before flashing them.
how do you get it to do this?
i have batista and i only have
wifi, data, bluetooth, gps, sound, rotation
can you change them?
I see there is a revamped S2 out that's hitting US and Canada shores either in September or October, possibly called 'The Hercules'. Same spec but it has a 4.5" screen. The physical phone has had a little touchup as well, removing the button and smoothing out the edges of the device. IMO I prefer the look of this.
Does anyone have any further information regarding this, specifically whether or not the uk will see a release?
You do yes, unless you're flashing official firmware via Odin.
Thanks, I was looking at trying the Batista rom first so had a search over at xda, assume I need to to this first http://forum.xda-developers.com/showthread.php?t=1103399 then crack on with the rom from here http://forum.xda-developers.com/showthread.php?t=1162715 ?
This was so much easier on my San Fran![]()
No, definitely not. Lite'ning 6.1 isn't good for battery, but that sounds rather extreme.
What does battery use say? Also, install BetterBatteryStats and check what's high in the wakelock stats.
I would do a little investigation first. You might find a rogue app or widget, remove that then calibrate -
http://hemorrdroids.net/battery-calibration/
Look for apps that monitor or update anything. Even worse, widgets that monitor or update.
I'll give you some examples of things I've found in the past -
1) An app that monitors your data usage
2) A widget that shows how long your battery will last
3) Google Latitude
1 and 2 I decided I really didn't need, so I removed them. Latitude I do use, but I switched to Latify, which I will review on Hemorrdroids in the next couple of days![]()
Thanks for the reply - How do I actually go about looking at apps that monitor or update? I only really have games installed.
Hi please can someone point me in the right direction to get official latest stock rom I had a look over at xda but I find itsiys all over the place and don't know if I'm getti g latest thanks guys
