- 12 Dec 2002
Well... I'm as far just doing the bits in the police station, I'm loving it!
I was wondering that, didn't want to risk it though.
Inventory seems like a massive issue with me...just found the rocket launcher which took up 50% of my inventory :/
Meh, the more I come back to the thread the more I realise, meh it wasn't that good.
It was enjoyable, but it was too easy and overly simplistic. but then, there was more than one route and most games don't give you that option. However, in saying that I don't think there was one critical area where using brute force rather than stealth made it almost impossible, or vice versa.
It would be nice if you try to stealth some area's but its just basically impossible so you're forced to fight, and vice versa, some area's so massively overloaded with enemies there is no choice but to find a different route.
One little irksome bug was, no matter how "strong" you are, you can't put down even a cardboard box quietly, I don't think it ever alerted an enemy but it was just irritating you couldn't put down anything quietly after picking it up. In a game that uses stealth so much and makes noise an issue, its just retarded.
Basically while good and better than almost anything out this year, as always on reflection you can think of pretty much dozens of things that could be done better.
The punching Aug is quite useful and you'll notice a lot of places to punch in when the walls are highlighted. I think theres 3-4 praxis kits to be had from punching, some easier routes, and in general it was useful and I only got it half way through the game as I was running out of crap to buy at that point.
Due to the weapon mods the aiming aug's were almost entirely pointless. Most of the aug's, except hacking, were pointless, two of the hacking ones were utterly not needed and the hacking mods made hacking "too" easy.
yea most levels were pretty crappy compared to the originals multiple choice routes...
in this the games multiple choice routes are basicly..
A through the door
B through the vent in the wall
The cloak is terrible though, even fully modded. And I have to say I really don't like the way they've implemented the charges/batteries, why not just give us 100% like in Deus Ex?I would say it is possible to stealth every area. You just need to be patient, and use the cloak properly. I only tend to take out the guards for the XP, but I have ghosted quite a few levels. So it is do-able.
Given there is an achievement to not trigger any alarms and also one to not kill anyone, it is possible to stealth all the areas.
yeah same here dude, i am looking for a hack, cheat code to make Inventory twice as long, or at least 3 columns longer![]()
You mean, the Inventory Upgrades you get which expand it by 2 columns each to double its size? If you're going all out combat then recoil, aim, inventory and armour are your 4 critical upgrades.
Though honestly I don't see the point in the Rocket Launcher at all. You get it in the same room as where you fight the huge robot and there is very little ammo for it and very little use for it elsewhere. Not to mention you can down these robots with a single EMP grenade.
You'd be more likely to spend your inventory space on a Sniper Rifle and Heavy Rifle and stockpiles of ammo.
Is it just me or does there not seem to be enough upgrades in the game? I've put every upgrade I found since the start of the game on my Pistol and its still only halfway to being fully upgraded. And thats just a single weapon, its spread even more thin if you have several.
Ummm;
