I uninstalled the Batista app.
Cheers!
My rom addiction has kicked in again just flashed leomar rom odexed will see how that performs against VR, so far its fast and smooth alongside ninpo kernel undervolted. VR is still my all time favourite rom.
mrgubby, is there any way to change the messaging shortcut at the bottom of the homescreen for a different one? I want to use handcent but holding to drag to the bin doesn't seem to work![]()
Erm I think they are diff mrk, these are what are on 3.7.4 http://imageshack.us/photo/my-images/696/snap20110828144036.png/ there is a patch on his thread to use 3.7.2 theme with 3.7.4 though here http://hotfile.com/dl/128373763/82a8dba/Tema_universal_style_3.7.2-signed.zip.html which uses the icons on the main pic in the first post on the thread http://forum.xda-developers.com/showthread.php?t=1162715
You mean the icon or the application? If you mean icon you could install Go Launcher?
Is that installed via recovery?
Well it's just the shortcut, there's 4 at the bottom on the home screen, Phone, Contacts, Messaging, Apps. I want messaging to fire up Handcent or be able to remove messaging and replace with the Handcent shortcut. I'll check Go Launcher, but thought it would be easy enough to change![]()
