What about those chinese systems touchscreen with oem fitment
Can be found on eBay look ok.
I think we've finally reached a point where it can be done without looking totally horrendous (Though opinions on this side of things are not required thanks very much)
I always thought double din units looked iffy in a E39 due to the fascia/ bezel ?
not the actual unit itself.
really? in the old days, if you wanted your HU to have permanent power (even without the keys in the ignition) you just moved the switched live to permanent feed. That would keep the HU on regardless of what you were doing with the car (starting it, etc). I guess older cars had less draw back then?
I kind of spur of the moment bought the Sony... Need to find somebody to fit it now.
I'm sure I can fit it but I don't really want to rip off the panels to do the cabling. I WILL destroy something.Do it yourself, fitting headunits is the easiest job ever.
[TW]Fox;19955110 said:Crikey, you make me look daft, I'll need at least 6 weeks more research before clicking buy![]()
How much do you really want an oem look?
I'd retrofit the BMW nav and be done with it tbh. Granted you don't get full postcode search, but the 4-5 digit search was good enough for me, and a recent map disc is all you need to have decent european-wide routing.
Can you get any DI-NOC stuff that could make the bezel look a bit more integrated?
