****The Official Samsung Galaxy S II Thread***
Same, just installed it and am reflashing all the various mods I like (silent modded new camera, no home button wake, no boot sound, stock overscroll animations, 3.7.2 theme, hardware camera buttons, speedmod kernel etc.
mrgubby, is there any way to change the messaging shortcut at the bottom of the homescreen for a different one? I want to use handcent but holding to drag to the bin doesn't seem to work :(
Sorry, I haven't got a clue. I installed Launcher Pro as soon as I flashed it :(
No chance you could create a list to save me trawling through all the posts on XDA? Or is that all?
I don't like the animations this guy uses so do have anything to make them stock.
Also anyone else having a problem on Batista (latest version and 3.7.2) where when re-downloading all your apps it says your phone has no storage space?
Press menu and then edit when inside the apps menu. Then simply drag it away and replace it with your Handcent one :)
Yay! Why couldn't they do that in the first place. That will mean a 2 day life with moderate usage easily. Just hoping my case will fit, although it is slightly loose already :)
Redownload apps? I use Titanium Backup to restore my apps so don't have that problem!
As for the list, the above is pretty much what I do. The animation of popup dialogues where they fly in still stays though, just the overscroll glow and scroll animation is reverted to stock as is the theme to the 3.7.2 style.
I did a full wipe and it began to fetch all the apps I had automatically and then half of them wouldn't install because it said there wasn't enough storage. Doesn't matter though as I have a titanium backup of them.
Ok thanks.
lol thanks,
went into clockworkmod, i want to back up the stock ROM before apply custom ROM but there is no option to backup in CWM menu
how to back up the stock rom?
thanks
