- 7 Jan 2009
Hey guys,
Im having an issue trying to set up Raid 0.
I have two exact matching 250GB Seagate Barracuda 7200 Rpm,Sata2 drives. and the motherboard i have is a Gigabyte P55 US3L.
Ive followed exactly the instruction in the Motherboards Manual on how to Set up Raid..
1)Connect both drives to GSATA2_0 & GSATA2_1 ports on the mobo (Done)
2)Go into Bios...do the following...
3)Save changes and exit Bios (Done)
But this is where im stuck after this,It says in the manual after the above to then restart the pc...and press CTRL+G to get the "Raid Setup Utility" but the problem is im hitting CTRL+G and nothings happening...its just booting into windows via my SSD.
Appreciate any help guys,First time setting up Raid!
- Enable Onboard SATA/IDE Device (Done)
- Set Onboard SATA/IDE Ctrl Mode to RAID/IDE (Done)
