- 20 Apr 2004
- Somerset
Do they make a noise? I like to imagine that they start up with an electrical fizz
First thing that went through my head when I saw this;
My Tubes are rated for a 10,000 hour minimum lifespan as long as the drive voltage doesn't exceed 200V.That is so cool, I want one now!
How long do the tubes last? As supplies are unreliable it may be worth stocking up...
edit: OK, wikipedia says upto 200,000 hours for the more modern tubes, that's almost 23 years of constant use so not as bad as I thought. A couple spares may be handy to have though.
Ever since my phone replaced my clock, calendar, camera, and also became a mobile internet device, I've never really needed any of those functions on another device.
Mobile phones ***!
Good point actually, I wonder if anyone has created a nixie clock theme for one of the many clock apps out there. I use Kaloer Clock on my AMOLED phone so all you see is the digits in the dark, one like this would look amazing!
As for the DIY, you could make it without abase, go Skeleton case look or mesh out some parts like those Gigabyte motherboards, looks ace.
Ace, I love a bit of soldering.
Now checking those links you posted.
Thanks a lot for the heads up, fun times ahead.
Where did you get the kit from?
And why are the flexible version tubes so much more expensive than the not flex?
Came as a kit, took me a couple of days to put together. The most soldering I have ever done in my life!
The tubes are IN-18's, and the whole kit cost around £400 I think, maybe more.
it's a true beaut
That looks nice, do the tubes get very hot? If not then I'd be tempted to go for some sort of wooden enclosure in order to pull off the retro look.![]()
DO WANT!
How much we talking?
You can tell you were back from on the lash with soldering like that![]()
Anywhere selling complete kits. But I guess it isn't too hard to get the kit and tubes seperatly.
Whats a good price for some fairly sized tubes?
I'd not wanna go anywhere near the £400 mark, it's very cool, but a £400 clock, I think not. Could it be done and still look good and not tiny for under £100?
Do they make a noise? I like to imagine that they start up with an electrical fizz![]()
Tubes with solid Pins can't be soldered directly, the pins conduct too much heat and crack the glass, ruining the tube. because of that, solid-pinned-tubes need to be used in conjunction with either their exceedingly rare original sockets, or you need to create the sockets yourself.
Thin-wire tubes are much more convenient because they can simply be soldered in place by hand without any form of fancy mounting.![]()
You can buy single pin sockets that solder on to a PCB and will take the pins![]()
The tubes are soldered in place and they're a MASSIVE pain to solder, so swapping them round isn't practical unfortunately, as that's a good plan.Cool toy!
Sounds like you could get more life by rotating the tubes once in awhile, if it isn't too much bother. Maybe once a week put the one from Slot 1 into Slot 2, 2 to 3, 6 to 1, etc. That zero on the far left is going to be lit up for 20 hours a day.
That is very funky![]()
Lesson learned: when I build mine I will socket the tubes.The tubes are soldered in place and they're a MASSIVE pain to solder, so swapping them round isn't practical unfortunately, as that's a good plan.
Makes sense. Good to know!interestingly enough, with Nixies, the digits that aren't used are the ones that degrade in static displays, as metal emissions deposit on the inactive digits, covering them up and stopping them from functioning.
This guy looks to be quite the expert:
http://www.tube-tester.com/sites/nixie/different/cathode poisoning/cathode-poisoning.htm![]()
it wouldn't work out any cheaper actually. the kits are remarkably good value.Of course, you have to ask how much extra you're paying for a kit over buying parts separately. If somebody put together a basket on Rapid it would be just as easy to buy... main disadvantage being the lack of a printed PCB, so you'd either be making your own or using perfboard.
Indeed, and i suspect that their quality is unparalleled. unfortunately, so is their pricehe also appears to sell kits!
i call it Veroboard still
for one thing, the wiring for the clocks (even if you use multiplexing instead of direct drive) is unpleasantly complicated. doing it in perfboard (i call it Veroboard still) is possible but very challenging.
Indeed, and i suspect that their quality is unparalleled. unfortunately, so is their price![]()
