Caporegime
- 18 Sep 2009
- Dormanstown.
No can't see it being as bad as 40% or else AMD can just write themselves off and go defunct.
Hopefully the gap will be 20-25% and SMP will be better than intel - If so I'll take a punt with AMD and build a machine for virtual hosts.
Can't remember the last time I bought an AMD chip (2003 / 2004 ?)![]()
http://www.anandtech.com/bench/Product/288?vs=88
Admitting, the 2500k has 100mhz more.
But the difference is currently massive.
That gap widens.
Their clock for clock difference means absolutely zero (outside of enthusiast circles) if the performance is the same or cheaper for the same price, along with TDP/etc in server spaces.
I'm not saying that BD will be awesome and for all I know it could fail massively. If it does, though, it won't be for the reasons that seem to be coming up in this thread.
All I've said is, the gap's widening between AMD and Intel, it's very possibly if that doesn't change, AMD can't offer the required performance in X amount of years, of course, software could become much more multithreaded to take advantage of AMD's "Throw more cores at it" approach.
Yes, they're priced differently, but I'm not on about price at the moment.
Price/performance wise? The 955's a lot better.
40% on average, as there's cases where it's not that, it's less, but in other cases it's 50%. So, 40% on average seems fair.
EDIT : Here's AMD's 6 core at 3.3GHZ versus the 2500k.
http://www.anandtech.com/bench/Product/288?vs=203
While it does help slightly, it's still got 50% more cores, but no where near the same performance on average.
EDIT: Plz don't quote Llano
