F
AMD
I
L
so far we've only seen results from ES chips
If those benchmarks are based on an engineering sample (which I presume means not what the final product will represent?) then surely that reviewer would have been aware of this and reflected it in his final comments?
You knew my point.
And its is easier to hit a TDP and stabilty at lower clock than it is at higher clock for the same silicon.
Both heat and stability are the most important factors for servers.
Most home users & the average consumer don't have the luxury of multi socket servers so the reliance is on a single chip so more is required from that single chip and a higher clock made be required to get satisfactory results.
Obviously, at the moment they have a place.
But we're seeing the gap increase, my point is, in a few years, if the current trend continues, will AMD be able to offer the performance needed?
But Llano's is newer than Phenom II and has the same IPC as Athlon II, Llano is also newer than SB.
SB-E is out this year, and Ivy is out in a few months.
The gap will only increase. That's what I'm getting at.
This was my point you even said it, heat and tdp are a BIGGER issue for servers, not for home, and its NOT easier to get the TDP right with lower clocks. Sure its easier to get 95W max at 2.3Ghz instead of 4.2Ghz, the problem is server parts are aiming for 2 entire chips at what 125-130W, so at 2.3Ghz they aren't aiming for 95W still, but closer to 60W. Because of the various parts of the cpu that will use similar power, memory controller, etc, dropping clocks doesn't scale very well with power usage, gating them and turning them off at idle is awesome for power saving, dropping clocks does smeg all. Phenom 2's, I get about 10W saved going from 3.5Ghz at 1.35v, to 3.8Ghz at 1.4v. The clocks are lower, the target TDP is also lower. The server parts HAVE to hit the targeted TDP, AMD and Intel have had no issue with higher wattage parts, and releasing them at higher than expected even 140W wouldn't have hurt them all that much, especially in desktop where no one really cares or pays attention to power bills or the real power usage.
If you have chips working over their TDP then server isn't the place for them, its the last place to put them. One chip at 125W as the highest parts are rated is far easier than 2, at a similar tdp.
http://www.dailytech.com/AMD+Ships+Worlds+First+16Core+Server+CPUs+New+Fusion+Chips/article22658.htmAMD Ships World's First 16-Core Server CPUs, New Fusion Chips
Company, however is reportedly struggling with clock speeds for quad-, octa-core Bulldozers
I'm not going to split hairs with you.
Which again is easier with lower clocks & requires lower v core which in turn produces less heat.
Example stability at 2.6 Ghz at 95W is easier to hit than 3.2 at 95W, more of the chips from a batch will be capable of 2.6 Ghz at 95W than 3.2 at 95W because more will require vcore increase for stability at 3.2 than the the few that do not, but 2.6 is enough for the server market initially so most go out as 2.6.
And im not going to spilt hairs over amps.
I'm not splitting heirs, you're missing what I'm saying completely.
A chip finds it easier to get under 95W at 2.6ghz than 3.2Ghz, the point you're missing is, the 2.6Ghz for the server chip, actually has to be 55-60W, because they stick two on a die and that entire 16 core chip has to use, not much more than the single core.
So, it's well over due and slower than Intel, nice one AMD.
