OcUK H²Flo Liquid CPU Cooler - IN STOCK NOW! (now with benchmarks)
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi all.
We have now got a great deal for you guys. This is in essence a Corsair H60, as it is manufactured for OcUK by the same company who make the H60 for Corsair.
The only difference is you have the freedom to choose any fan you want, oh and you get to save a few quid too :)
OcUK H²Flo Liquid Cooler Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £38.99 inc VAT
The OcUK H²Flo Liquid CPU Cooler is a fantastic product aimed at medium to high end CPU cooling, with the power to slay any overclocked CPU temperatures succesfully. The cooler houses a large surface cold copper plate to ensure all the heat is drawn away from your CPU and transferred to the sealed liquid and the pump then transports the liquid round to the radiator which then cools the liquid back down to enable the liquid to recirculate back to your CPU block to again pull more heat away. All you need to do it add a fan of your choice to the radiator and your CPU will be cooler than the next Ice Age.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Support: 120mm x 25mm
- Cold Plate: Copper
- Radiator Material: Aluminium
- Thermal paste is pre-applied
NB: No fan is included.
Only £38.99 inc VAT.
ORDER NOW
We would recommend either of these fans for the unit.
Sharkoon Silent Eagle 2000 120mm Fan - 3/4 Pin @ £10.99 inc VAT
In comparison with conventional fans the unique surface structure of the Silent Eagle allows an improved airflow - at the same rotation speed. This principle is based on the surface texture of a golf ball, which helps to reduce air resistance and turbulence, resulting in particularly quiet operation while maximizing airflow volume. In addition, the rounded edges of the Silent Eagle's frame offer a markedly improved air intake.
- Dimensions: 120 x 120 x 25mm
- Rated speed: 2000 RPM
- Sound: 36.1 dB(A)
- Air flow: 76.4 CFM
Only £10.99 inc VAT.
ORDER NOW
Sharkoon Silent Eagle 1000 120mm Fan - 3/4 Pin @ £10.99 inc VAT
- Rated speed: 1000 RPM
- Sound: 19.0 dB(A)
- Air flow: 36.8 CFM
ORDER NOW
You can save £10 against the Corsair H60 and the Sharkoon fans should be better performance at the same time :)
How long's the warranty?
Got any benchmarks for us? (I'm guessing you're going to tell us they're identical to the H60's) but would be interesting to see with your recommended fans....
kd
Not got any benchmarks at the moment. I will see if we can get some done over the next few days for you.
I'll wait for a couple of benchmarks before i decide on this one,But i must say this looks a lot
sleeker than other closed water units.
:D
Makes you wonder how much it costs them to make and how much Corsair are making on top for slapping a Corsair sticker on and including a fan with a sticker on as well. I'm sure these will sell like hot cakes! (I think that's the expression, might have got it wrong though.)
The logo on the block shows who makes these. A bit of research should show you the manufacturer of this unit.
How come you guys stopped stocking their stuff? (I'm sure you used to).
Need to get some of their other sized radiator versions and bundle them with some cases. ;)
