nearly all the CPUZ's i've seen are either ES chips or oc'edWho said anything about OC'ed?
The CPUZ's were at stock.
The P4's were there before weren't they? And they were single cores.
You really have something against ES chips.nearly all the CPUZ's i've seen are either ES chips or oc'ed
Can't you just consider it an educated guess? Everyone does it. For one thing, If the ES chips are using 1.4, then if anything the retails will use less or the same for stability. Certainly not more.
Hardocp has a 13 min vid up of the event
http://hardocp.com/article/2011/09/13/amd_bulldozer_fx_model_8150_cpu_overclocking_preview
) it might be worth a punt for my self...Hardocp has a 13 min vid up of the event
i'm talking about the 24/7 ocing.Can't you just consider it an educated guess? Everyone does it. For one thing, If the ES chips are using 1.4, then if anything the retails will use less or the same for stability. Certainly not more.
One of those processor had 7.2 ghz @ 1.272v and a 7.7 @ 1.224v
Those are some very wierd numbers....
Ha, this is kinda funny for me. Back when I first got into building my own PCs Intel held the clockspeed crown with some liquid nitrogen nutters pushing Pentium 4s to 4GHz+, but AMD's Athlon XPs were outperforming P4s at much lower frequencies. How times have changed eh?
I don't think these will be able to beat SB even when overclocked, cause let's face it, SB also runs cool and clocks well. Not that it matters, as they will definitely make a killing in the server market. What AMD needs is not the performance crown, it's to sort out their manufacturing capacity problems! It was a stupid mistake spinning out GF, you can be a fabless chipmaker if you're ARM, cause then you're not actually selling chips yourself, you're just lisencing yoru design - but if you're actually in the chip-selling business, and you're a high-end CPU maker and only 1-2 fabs worldwide actually have the capability to manufacture your chips, then you're basically at their mercy, which is awful!
Maybe they could use Intel?![]()
This post appeared on the forum of a competitor and was made by one of their employees:
"The things i can tell you.
1. Bulldozer is here mid-Sept
2. Bulldozer will be very price competitive vs Sandy Bridge
3. Bulldozer is awesome - ha lol.
4. Every part is unlocked
5. It can OC very well!
6. AMD will be doing something special with LN2 very soon - 1-2 weeks. "
Anyone else having a late one to find out what the 2am announcement is??
