****The Official Samsung Galaxy S II Thread***
The official mesh cover looks very good but all it protects is the back, which doesn't need protecting (IMO), it leave the front and side vulnerable to damage.
I got a few from evilbay and have stuck with a leather wallet.
I like the look of the mesh cases but having a look at some over the weekend came to a similar conclusion so plumped for a white silicone case which makes the phone bigger in the hand but easier to hold for me and if i do drop it the sides and screen are way better protected as the silicone puts a lip around the screen oh and a screen protector of course.
Its for use at work I dont have WIFI @ Work
Yeah I could but I am just a lazy B'Stard and it was a really nice feature for the HTC, so I am wondering does it exist for the Sammy
As Kreeeee said, GS2 has tethering which you can use the USB cable or wifi.
I use it with my tab 10.1 and have my phone sitting in my pocket :)
I am finding the phone's wifi reception isnt that great if I am not within afew metre's of the source. Is there a way of improving/boosting the wi-fi reception either through ROM or add on? I am currently: 2.3.4 running VillainRom 2.4.2 with ninphetamine2.0.4
Cheers
Wise choice I'd say.
while the mesh looks great I've dropped my phones, screen first on pavements before and they've survived OK with the eBay gel cases, the extra bulk's worth it.
Cheers
wifi is fine on stock kh3 2.3.4
how do i check if HSDPA is enabled, i see the 3G icon quite often but, i'm assuming there is a H sign for HSDPA. which i have yet to see, any way of telling or connecting?
the 3G icon is when the phone internet is idle - you get the H symbol when actually using the internet in a HSPA area.
Cheers
Samsungs idea of what is a strong signal seems to differ from other brands. To alleviate your worries run Wi Fi analyser from market and you should see exactly what signal you are getting. Basically what Samsung considers 2 bars in strength , others would say its 3.
ok thanks, so i do not have to turn anything on or anything :)
Are you sure about that? On my OSF and the wife's Sensation the icon shows what you can use.
So If I'm in a 3G area it says 3G when I get to work it changes to H
i'm not sure on that either. 3g is different to hsdpa right? it's like 3.5g?
if i get the H symbol i get decent speeds, if i'm using 3g then it's carp and slow
Just received a s2 as an upgrade from my desire. Only issue i am having is that my gmail is not pushing? anyone else having trouble?
You don't have to pay.
what he said. if you have an android phone the T+Cs say (or said) you get 3GB with full speed downloads. otherwise it's 1GB and a cap.
the trouble is, technically the former isn't available if you got your phone through someone like carphone warehouse. only if it's direct through t-mob. saying that, going in store and saying your speeds are slow can usually help a lot :D
