Ok...just bought the standard edition from tesco's got it home, ripped off the cellophane and i can't open the damn box!!
Theres a red tab alone the spine where the box would typically open, any tips?!
......Just started Act 1 on Insane.![]()
Trust me you ain't doing this one on insane on your own. Not without it taking you forever. I'm amazed how tough they have made it. I've been ducked behind cover with a tiny bit showing and they have one shot killed me from as far away as they can get on the map. This wouldn't have been a problem so much except there is no more reviving on insane.
The others I got through on insane, not a hope on this for me. The silly thing is they made the ai help excellent so they push forward and don't get put down while you have you head sniped off with 3 pixels showing.
You could never do insane on 4 player co op without going out of your mind every time one player got dropped.
I've always said its far too tough to get all the variable right on 4 player co op. Gears worked quite well with 2 players to get the balance even if you then played alone. This time it's madness.
It's so hard this time with no revives I can't be bothered. I was getting on hit insta killed when I got to the playground on chapter 3 act 1.
It's possible to use 3 friends of casual you on insane but I can't be bothered wasting 10 hours or more for 75gp.
You can play it on arcade which makes it easier as you will respawn if one stays alive.
Failing that you can do it in coop with your mates on an easier setting and just let them clear it out.
I'm not having too many problems at the moment, ive nearly finished act one on my own.![]()
You can play it on arcade which makes it easier as you will respawn if one stays alive. .
Just tried it on arcade insane and it was still instant death?
Single player or in Co-op?
I'm only going by what I read though, not started the campaign yet.![]()
The Silverback in Horde mode is sick to be honest. A killing machine. Works wonders against Brumark.
