Red Orchestra (2) : Heroes of Stalingrad
i must have bad eye sight or some thing , i cant hit anything in game! i will be hiding behind something and get shot dead.
see someone for split second and dead!
do people run this with min gfx settings so there is no effects! i love the smoke etc and bloom , but it makes things a lot harder to see , so do hard core player play at min settings to speed up there aiming etc?
Grrrrr this is annoying me now:mad:
It can fine for a short while then for no apparent reason I cant respawn, i'm stuck in spectator mode.
It was suggested to press alt +f4 but no joy, any ideas? thanks.
It happened to me once I had reset the game.
This has happened a few time now, I even switched sides and I managed to re spawn but it was short-lived:(
Happened to me aswell about 20mins ago!
To get it to work again, change your role.. however it can respawn you and kill you suicide :o
Just had an awesome match on Loam's beer drinker server, 32 players is a lot better it was also a smooth server.
This isn't a bug, it's someone taking your class.
If someone is doing well it gives them a battlefield commendation and they can choose any role they want.
What the game doesn't do is tell you that someone has taken your role, so when you die you get stuck in spectate until you change your role/class.
It's annoying as hell and has happend to me on quite a few occasions
FallenFighters has swapped sides 3 times in a row now.
This has happend quite a few times on FallenFighters,
You get people who just sit in spawn even if they have to attack which just results in no one winning and it just keeps rotating.
And the same for this map on TE, because all the points are so open it just encourages people to camp in spawn/windows and makes for terrible gameplay.
You end up with about 5/6 people on both sides trying to get the points while the other 26 people on either side camp at spawn.
I personally think it is the worst map in RO2 hands down :(
EDIT : Nope logging off, Couldn't hit a thing and everyone was spot on with accuracy at 300 meters plus. Will play later...
Is that fallenfighters map the big snow one? With like a park in the middle?
If so, I hate that as well... me and AK were trying to coordinate attacks on it, but unless you get an active SL who will actually cover your attacks with smoke, then its like trying to run through a rainstorm without getting wet... pointless.
A few points from playing recently:
Tanks are pretty lame, I have experminted with being AT gunner and having no sucess smashing the back or the side of the tank, am I missing something?
The tank AI on machine gunner is basically just a wall hackng aim botter that can pick your face off from across the map and through smoke. Needs toned down massively.
I am finding servers with 32 players or just between 64 and 32 the best for teams going for the objectives and keeping performance at a much better rate. As much I want to play on the OCUK server, 64 players is sometimes just not as fun due to hit on performance and the team play mostly going out of the window.
I didn't realise until last night that as Axis on redoctoberfactory map, you can fire straight into the spawning Allies team. Massively lame and I felt bad getting 6 or 7 frags before realising the enemy were simply spawning infront of me.
Fallen fighters is an awful map. Just a massive campfest.
That map drove me nuts! to many campers on the attacking team for some reason, and when your squad leaders are camping your basically screwed. There was like 6 people in the spawn building camping and the other 70% of campers chilling outside spawn 1.
I do love the game, think it's the best WW2 shooter since CoD:UO for me, but the server browser issue is really peeing me off.
We just can't ever see our server in the Ranked listing. Only time it shows is if we're really lucky after a server patch to get the game back up & running, only then do we see it.
If anyone can see the [XSG] server (apparently John Gibson can) can you let me know as we had it full 2 days ago & then bam, never since.
Making me a sad Panda :(
